v1.5 problem
Hallo can somebody explain what I have to do ?
I have used Defraggler for long time , no problems, after installing v1.5 I was defragging my C/ and Defraggler crashed two times, finally after defrag is finished my system is works very bad, music sound shocking, files accesed very slowly, start up time twice longer than before.
Do not know what went wrong.
Any ideas how to fix system ?????
You mean v 1.15...Right ?
Yes I ment 1.15 , and its happened with XP SP3
Still can not figure it out , looks like my hard responding very slow... :(
For pplz with similar problem:
I defragged C with integrated Windows tool, now C responds much better, some files couldn't be defragmented though, but on the D drive still same problem, for example if I play music from folder on C works OK, if I play from D drive sound is chocking. I will try to defrag with windows drive D. Looks like Defraggler v 1.15 made major mistakes during defragmentation, hope that developers will fix that issue soon. I do not like to use windows tools, in fact I do not like windows at all , forced to use it as many others , looking forward to some free , open source OS.
