V1.28.277 Causes Macromedia Flash Problem
Hi all,
The Preliminaries:
Operating System is Windows XP Home Edition SP2.
The Problem:
Ran v1.28.277 with CCCleaner optioned to clean all Applications.
Noticed it found a Macromedia Flash 8 key to delete and clicked OK.
Later went to a website that told me I needed to install Macromedia Flash to view the site.
Went to the Macromedia download site and reinstalled it (online); verified OK by Macromedia.
Went back to the original website (that told me I didn't have it) and they told me the same thing again.
Tested other Flash sites with same results.
The Solution:
Completely removed Macromedia Flash 8 via the add/remove programs and did a full reinstall at Macromedia website.
pent7301
Glad you found the solution. It's time to update your CCleaner, there's a new version available here!
