hzne
1
I have a list of cookies to keep for not log in on my favourites sites.
The version 2.17 worked perfectly with IE 7, but not with IE 8.
The version 2.18 does not work with IE 8,
and I am obliged to log in on every visit on my favourite sites,
but the cookies are saved on my computer ????
Excuse my english, i am a french user.
OS : XP PRO SP3
PS : Before this post, i have deleted all the cookies
and the saved list in CCleaner.
I save a new list of cookies for my favourites sites,
but it don't work and i am obliged to log in to every visit
I need some help.
OS : XP PRO SP3
I need some help.
You need to untick/uncheck Index.dat files in Windows tab>Internet Explorer.
This has been reported elswhere in this forum.
hzne
3
Thank you for the answer.
It is about a temporary solution because the file index.dat
is going to record all the navigation.
I hope that a solution will be found during the next update.
You're welcome.
Yes, a fix and update is needed quickly.
hzne
5
Unchecking Index.dat files in Windows tab>Internet Explorer
don't work ;
and I am obliged to log in on every visit on my favourite sites.
![:angry:]()
don't work ;
![:angry:]()
Hi,
You have to untick them in CCleaner. You'll find the tick box under "Cleaner/Windows".
