Using CCleaner v2.01.507 from a USB flash drive
I have CCleaner v2.01.507 installed on one of my computers. If I copy CCleaner.exe from that computer to a folder on my USB flash drive, put that USB flash drive in another computer, open CCleaner from the flash drive, select the option to "Save all settings to INI file," and run the cleaner and registry issues tools, will CCleaner leave any traces whatsoever (such as a registry entry) on the second computer? Or do I have to actually install CCleaner in a folder on the USB flash drive and/or select the option to "Save all settings to INI file" before I even place the USB flash drive in the second computer? Thanks.
Damon
