Hi All,
I am very new to this and I can't seem to find an answer on the site. I have successfully installed Ccleaner on my computer and have cleaned my user. However, when I try to log on as other users, I can't seem to find the Ccleaner short cut or the program listed in "all programmes". Have I installed the program incorrectly. I would be grateful for any help.
Many thanks
Yes, I believe CCleaner does that - it installs the shortcut only under the user that installs it.
The easiest solution is just to copy or move the shortcut/folder from the install-user's Programs to All User's Programs folder, i.e.
- move %USERPROFILE%\Start Menu\Programs\CCleaner
- to %ALLUSERSPROFILE%\Start Menu\Programs
That is indeed correct and you may want to copy the desktop shortcut if you want that also.
I.E.
* move %USERPROFILE%\Desktop\CCleaner.Ink
* to C:\Documents and Settings\All Users\Desktop\CCleaner.Ink or C:\Users\Public\Desktop\CCleaner.Ink
