Using 2 installations of CCleaner or profiles
Here's my problem:
I wanna use one installation (or profile) when windows starts, then I wanna use another installation of CCleaner (or another profile for the first installation).
The idea is to avoid changing the Windows and Applications settings all the time.
An example:
I want to run CCleaner when the computer starts but without the "Wipe Free Space" option.
If I run CCleaner by myself, then I need the "Wipe Free Space" option activated! (Mostly I forget to deactivate it before I shutdown Windows!)
Another idea is to use a batch file, starting/running CCleaner with variables (activate/deactivate the options I need).
    1. Is there a possibility to use Profiles with (better: in) CCleaner? (found nothing)
    2. Is it possible to work with 2 installations of CCleaner? (I’m afraid to kill my registry or something like that while trying)
    3. Is my batch file notion a realistic idea? (don’t know anything about the “variables” to take)
Are there any ideas or maybe a solution?
Regards, ZikZak
Not possible, beeing the first one - thinking of it!?!
Possible solution would be to use two portable editions extracted into their own unique folders, of course keeping them straight would probably mean to name the folders according to your needs. You can get the portable edition here:
http://www.ccleaner.com/download/builds
Hi Andavari,
My security software is freaking out!!!
Thank you for this link...
Now, I'm using the "standard build" for running with windows starts
and the "portable" Version with own ini, running with a double-click...
It is working perfect without security warnings!!!
Thank you, Andavari!
