Using 1.34.405 slim.
I installed the 1.34.405 slim. Is there any reason for me to update to 1.34.407?
"(Updated from build .405 to fix some foreign language issues.)"
I couldn't care less about foreign language issues since I am using the english only slim build.
if thats the only change, then no.
as long as you use english, you should be just fine with the version you have.
i like to upgrade anyways though, it only takes a minute :D
