Hey!
My laptop ethernet jack is broken....finally after 8 longs years..
I was looking at some USB to ethernet adapters. Its just plainly an outrage to spend $22 on a highly rated belkin adapter.
on ebay, i found one quite cheap
http://cgi.ebay.com/NEW-10-100-USB-to-Ethernet-Network-LAN-A
dapter-NIC-RJ45_W0QQitemZ160218554918QQihZ006QQcategoryZ1118
2QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
it seems that that product is the only type on ebay...so, does anybody have any suggestions for something under $7, or do the ones on ebay work well?
thanks!
