Today i used my USB Drive in a computer to copy some files, when i started copying the files, the antivirus picked up all the folders i had on the drive as virus, and now all my folders have the .exe extension. I can not access my files at all.
The experts will probably get back with you pretty quick. When they do I bet they'll want to know what antivirus you are using, what kind of USB drive, which OS, other details.
Yes, used older ver. 0.88.7, right now running latest as we speak. Has good features: manual update button, memory scan button, selectable file scan button, preferences button. Not fast. Do not know about the detection efficiency. It says Detect Keylogger.exe is a trojan, but i don't think it is. . . . . . if it is, somebody tell me.
Any experience of the full Clamwin Antivirus? Another free product.
Yeah, it's slower than any antivirus I've ever used!
Which is why I'm using AVG Free as my resident antivirus, and I installed AntiVir without the guard as my secondary antivirus. Doing things vice versa isn't something I'd do because AVG will constantly warn about the resident shield being turned off however AntiVir shows no warnings when the guard isn't installed.
