Upgrade to CCleaner Pro Plus
I had the free version of CCleaner on my PC and just purchased CCleaner Professional Pro where I asked for the desktop icon to be created. When I click on the only CCleaner icon on the desktop it brings up the free trial version. There is no desktop icon for the Professional Plus. Does the paid version use the same icon as the free version? I note when running from that icon there are still many things it does not check. I just want to make sure I have installed and am using the one I paid for. Thanks.
have you plugged in your license key yet? (Options, About, blue License button)
that will make the Trial version go to the Professional, non-trial, version.
then the same desktop icon applies.
