hi fans,
i tryed the update from my old installed v1.11 (free home-version) to v1.17 and it do not work.
it is just a temporäry failure?
hi fans,
ok, i see this popup at the login... perhaps the update will be later :-)
That link in your screenshot was posted in October 2019
https://support.ccleanercloud.com/hc/en-us/articles/360035098352
Your CCleaner Cloud account is safe to use and you can continue to use it as normal. However, the reissuing of a new product certificate means that you are currently not able to add new endpoints to your account. We apologize for this but hope you can understand that your security is our priority.
We’re currently carrying out a little development work to get things back to normal again. We kindly ask for your patience on this and will update you on our progress as soon as we are able to.
Months later people are still waiting.
thanks for your answer hazelnut :-) perhaps later an update-in a few months or so
why am I unable to update to 1.17.603?
