I have been using this program Update Checker for sometime and I have been very satisfied with it until recently. However the last few times I wanted to update my softwares this program wouldn't start and I had to reinstall it in order to run it, meaning that after reinstall it works fine, but if I want to run it again later it will not start at all.
I was wondering if there is a solution to this, my laptop is functioning without any problems and I am only experiencing problem with this program.
Thanks for the reply. Yes its the same Update checker as you mention from Filehippo. I have been using it for more than a year and it had been working well until now.
No I didn't uninstall it, just downloaded a fresh copy and reinstalled it.
I haven't tried the standalone version of this program, I'll try it and see who it works for me.
You may have been trying to reinstall over a corrupted install. Sometimes that can fix things, but to make sure it's best to clear the old install out completely first.
