Hi,
I have few suggestions for ccleaner.
1) Show Piriform's logo on the right of the bar menu (button right floated and linking to website/forum with auto loggin)
2) account the amount of data removed by ccleaner (throught all version).
3) Add the option for search and wipe registry issue.
3) Add the ability to add scripts or selections from the community.
As we can provide/export our custom selection.
I mean I never used the sounds or pictures of windows.
So I had there locations to my custom list.
4) I would like to know if Ccleaner can look for unused language repertory and files ?
Is there a way to spécifie a regular expression or alike ?
I mean some software (like Apple i.e. iTunes/ipod/quicktime) creates lots of files within repertories like "de.lproj".
Manualy I recover about 150Mo (not so much) but why should I let them occupy my disk ?
I sugest to have another interface for the custom files and folders selections :
a tree view with checkboxes ?
It will be more efficent than selecting the excluded thus the included files/rep.
ex:
http://terai.xrea.jp...thCheckBox.html
5) I installed ccleaner for a friend she did not recognize the broom on the icon. Is it too slanted?
6) I used the french language parameter. I when I run the Cleaner
I noted that it doesn't translate its processing steps.
Thanks
