Hi,
Thanks for your responses till so far.
The unicows.dll is in the CCleaner folder. So, that must be o.k.
I've also undo the installation and install it again : Same results. ![:(]()
My version is 2.9.0.600 and @ to Hazelnut, it does not show W95 or 98 in te properties.
Maybe another download from another location will hopefully solve my problem.
I.ll back to you soon !.
regards Jules
Hi again Jules,
EDIT
Do the following before anything else.
1) If you did not reboot after installing CCleaner then do so and try running CCleaner again.If it runs then see advice at bottom.
2) Download the latest version of unicows.exe (1.1.3790.0) for Windows 95, 98, and Me Systems from Microsoft web site at http://www.microsoft.com/downloads/details...;displaylang=en
3) Run unicows.exe and unpack it in some temporary directory.
4) Copy unicows.dll and unicows.pdb from your temporary directory into your <Windows 98>/System directory.
5) REBOOT your computer.
6) Run CCleaner and see how it works.If it does not work, do what follows. Let us know what happens as soon as possible.
Keith asked some questions and he uses Win98SE.Maybe your answers will help solve the problem.
Since the new version came out this morning,you are the first to report this problem.This is why your answers are important.
Put your answers right next to or under the question.
Did you reboot after installing CCleaner?
Are you running with Administrator privileges?
Where did you download from and did you try the alternative download site also?
P.S. What build did you originally download today?
P.S.What Language did you request if any?
P.S.What do you mean when you said "I've also undo the installation and install it again " ?
In what location did you download the Portable version?
Did you click on the CCleaner icon at that location?It is important that you do this.
OS,edition ,32bit or 64bit and version ?
Browsers and ver.?
Security software and ver?
Other data you think might be relevant?
What did you do and then what happened?
Be back with you later,
davey
The CCleaner Guide is your first source of information.
http://www.ccleanerbeginnersguide.com/ CCleaner Beginner's Guide.com
Bookmark & save to Favorites
See this link for initial advice to brand new user. http://forum.piriform.com/index.php?s=&...st&p=105208
Thanks for taking your time to make a report.
