The drop down box when viewing details in the cleaner is not wide enough to accommodate the text. See attached below.
![post-15598-1249250223_thumb.png]()
Steps to reproduce.
- Run CC and perform an analysis for cleaning
- When viewing the summary results, right click in the list and select details
- In the upper right corner of CC you will see the drop down box containing the different cleaning sections/components
- For several lines, the text is cut off
Possibly how you have Windows Fonts settings configured.
See this document to rule it out:
http://docs.piriform.com/ccleaner/ccleaner...s-ccleaner-uses
Im using 96 DPI and Segoe UI. I've never changed my default font settings aside from disabling cleartype.
96 DPI is the normal windows setting, however you may want to play around using another font like Tahoma, etc., to see if that's the issue. If it isn't CC probably needs to have built in font settings, allow for a scroll bar if it doesn't already feature one, or wrap the text because undoubtedly there are people that have no choice but to use a more legible font.
Im happy to report in v2.23.993 that the bug has been fixed. Huge thanks! ![:D]()
![post-15598-1251394786_thumb.png]()
