TypeLib Problem
Thankyou in advance for any replies.
I have a problem, CCleaner cleaned everything up but one registry key will not clear, it keeps re-appearing in the 'problem' list after cleaning the registry and cannot be removed.
This is what is left in CCleaner:
Missing TypeLib Reference IVideoWindow - {B9AA1F11-F480-4054-A84E-B5D9277E40A8} HKCR\Interface\{56A868B4-0AD4-11CE-B03A-0020AF0BA770}
Do I need to either re-install something? If so, How and what?
Or, is there a way to clear this item (I've tried many times already).
In cleaning my laptop, have I removed something I shouldn't have?
I've never had a problem with CCleaner before and I have been using it since 2004.
Please be gentle with me, I am an older person and I am not as tech savvy as some of you (lol!).
Thankyou again x :)
I am using the latest CCleaner version v 3.27.1900 (64 bit)
reading my signature should answer your question, you should research what the entry is (usually i**** entries are your security software but not always) and (if safe) add it to your exclude list
Chances are you have a software installed that you currently use which is re-installing the key. You could either ignore it constantly re-appearing or set and exclusion the next time it shows up by right-clicking it and selecting to exclude it.
Thankyou for replying. I will try excluding it when I run ccleaner again. :)
