Hi,
I have two drives one C and other E. Will CCeaner clean both? They are internal drives.
Kind regards,
Ken
Hi,
Kind regards,
Ken
CC will run against the system drive only by default. To run against other drives you will have to use includes, or wipe free space settings, etc.
Ok thank you. I have one more question is it ok to use on ssd which is the default drive? The other drive is reg. drive.
Yes, but I would not use secure file deletion or Wipe Free Space.
Great. which one is secure file deletion?
Multiple passes in the options.
Thanks for all your help, I get scared when things are getting deleted. That is good advice you put there.
Thanks again. Sure glad I asked you first.
King regards.
Ken
