Trouble with Thunderbird
Calling my ISP tech and find out from his end if he can do anything. If not I am going to abort the installation of Thunderbird and stay with OE6.
At this point , it seems to be an issue fof enabling another account or something.He is really good at trouble shooting small and annoying problems really quick.
Thanx RRidgely for the input..
Consider this thread closed .......
Let us know if you get everything fixed and such, please. :)
Will let you know , Tarun , Thanks for the concern :)
Details to come later.......
Problem solved.. :D
The incoming mail name pop.nmia.com was capitalized ( POP.nmia.com).
Funny how you can overlook the small things..
Don't sweat the small stuff.... :)
The password problem , I still don't know the deal...but its working and I am a happy camper.....
Problem solved.. :D
That does sound rather weird. O.o
Windows NT 4 is very old and you probably should consider upgrading the computer to Windows 2000, Windows XP or Linux.
If not, then be sure to use the latest service pack!
FYI==> After I created a new account I imported the settings and the mail.
This prompted the server to add another account which was my Bosses
with His user name & email addy but with my server settings?????
This is why I couldn't type in the right password because the server was
trying to log Him in instead of myself.
I just removed His account and everything was fine.... B)
I don't run out and buy a new OS everytime I have a small glitz in my current OS.
I try to isolate the problem , then analyse a solution , then implement the solution and if I cannot solve a particular problem I reply with knowledgable people who have the expertise to eliminate the glitz....
You see the key is finding the right people to fix your problem.... :)
But , thanks for the suggestion. B)
Leave it to Eldmannen to suggest complete replacement ?_?
