Trackers and junk not deleted
I am new to this forum and forums in general. I realise the issue of tracker and junk removal has been covered previously.
I ran CCleaner and it found '2001 trackers'. The clean up indicated '3 trackers removed'. I ran it again and it found '620 trackers'. The clean up again indicated '3 trackers removed'.
Junk removal follows a similar trend. Surely the whole point is to remove ALL trackers and junk.
Regards Peter
I suspect that you may have your browser synced? Have you read this:
If none of that helps then try doing an 'Analyze' with Custom Clean to give an indication of just what CCleaner may be finding.
It won't quite be the same as what Health Check finds but should be close enough for an indication.
If you could screenshot that Custom Clean results screen then that should give us and idea of what it is finding to be cleaned.
