Tools > Startup. How does it work?
Greetings All...
Under Tools > Startup, I can disable programs listed there so they won't startup when the computer starts up.
I was told by someone that the programs do start anyway at computer boot up time, but that CCleaner will shut them down after they have started, because well, I set them to "disable" and not "enable" in the CCleaner program. This is all under Tools > Startup.
I'm having a little trouble accepting this explanation of how CCleaner works with regard to disabling programs from starting up at Windows bootup time. It was explained to me that the computer will boot up slowly if I use CCleaner to disable programs from starting, instead of disabling programs from starting using the "msconfig" program.
I was told that if I use CCleaner to disable programs from starting up, then the computer will boot up slowly. But if I use the "msconfig" program to disable the programs from starting up... then the computer will boot up quicker.
I am being told to uninstall Ccleaner and not to use it to disable other programs from starting. I was told that using "msconfig" is the correct way to disable programs from starting, and that it is not correct to use CCleaner to disable programs from starting.
Is this true?
It would make sense to me that CCleaner would tell Windows to not startup any programs that were "disabled" by CCleaner.
It would seem strange to me to have Windows start the programs at boot time anyway, causing the start up time to be longer, and then stop (disable) the disabled programs after they are already running.
I don't understand how CCleaner works in this regard.
I don't care if I am currently right or wrong with respect to how CCleaner actually works.
I just want to have the truth on this issue.
Thanks for any help.
George.
Is this true?
you have been given a bum steer.
when you disable or delete an entry in CC, that is reflected in msconfig, so when Windows starts, what it sees in msconfig gets done at startup time.
Windows startup process does not talk to CC.
feel free to disable startup entries in CC (services however should not be done in msconfig - but that's another story for another time)
Hello George
Reading your post got me curious, so I performed a little experiment on my machine. I have a utility, Zemana AntiLogger, that starts along with Windows. I disabled it using CCleaner and rebooted. After reboot, I opened CCleaner and Task Manager side by side, and this utility was shown as disabled by both. Then I used CCleaner to re-enable it, rebooted, and it was shown as enabled by both CCleaner and Task Manager. I repeated this process using Task Manager to disable and re-enable Zemana, and the results were identical.
So whatever you do with CCleaner to change startup items makes the same change in Task Manager, and vice versa. Please ask your friend the "expert" to do some research of his own before giving you any more advice.
CCleaner's Startup tools of Enable and Disable have always mirrored what msconfig does!!! The main difference is the Delete button, use it with extreme caution.
and if you are wondering why Derek is talking about Task Manager, he must be using Win8 as changing the startup process has been moved from msconfig to task manager.
(just figured that may need explaining as you didn't mention your OS)
This is a great forum. My sincere thanks to all of you who responded with your wisdom. I will share this info with my friend.
Much appreciation. May God bless all of you.
George
