TomaWeb Color Codes
I have been using this amazing little program and thought some may find it useful.
Color Codes 1.1
Color Codes is a Windows utility that will let you pick your favorite colors from the standard Windows palette or from an image in the clipboard, and give you their equivalent in HTML HEX, Delphi HEX, and RGB.
http://www.tomaweb.com/color-codes.asp
