Hello
I'm trying to get ccleaner to run before logof of my Windows xp machine.
If i'm correct this is possible with group policies.
Now i want to make a vbscript which let ccleaner run with a custom settings file (.ini) so that i can say which items ccleaner should clean.
Is this possible and so yes what is the code for it.
Alan_B
2
I use a BAT script to replace the CCleaner.ini that resides in the same folder as CCleaner.exe with a selected replacement version of CCleaner.ini,
and then launches CCleaner.exe.
I see no reason why vbscript cannot do the same for you.
Just remember to wait for CCleaner to close and then replace the *.ini with the "normal" version ready for the next day.
