1. What are the benefits of Pro - e.g. CC Pro?
a. Assume it provides a license for use. Is version same as in free CC? Does it provide updates as free does or is that only a function of annual subscription (which also provides support).
b. Can Pro (CC) be run on more than one machine - e.g. a (new) laptop?
c. Assuming 1b is yes, does it matter that current machine is running on 32 bit OS and the laptop is running the same OS, but 64 bit?
2. Generally is it better to run 64 bit CC when using a 64 bit OS? Am aware than that 64 bit OS can/will run 32 bit programs.
3. How the dickens can I change my pw?
Any responses would be appreciated. Thank you in advance.
