The video driver does not work after cleaning CCleaner...
Hello all!
	I cleaned Windows 10 system with the CCleaner v 5.42.6495 utility and checked the box "cleanup of the old Windows installation" and now after the reboot I see a message that "the driver for the screen could not be launched". In the device manager, the video driver is marked with an exclamation mark. I tried to update the draver - but the problem with the driver in the device manager was not solved. </span><span style="font-size:16px;">Can you please tell me what to do?</span>
<div>
<div>
	<span style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">Всем привет!</span><br style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;"><span style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">Я очистил систему Windows 10 с помощью утилиты CCleaner v 5.42.6495 и установил флажок «очистка старой установки Windows», а теперь после перезагрузки появляется сообщение о том, что «драйвер для экрана не может быть запущен».</span><span style="float:none;background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;"> </span><span style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">В диспетчере устройств видеодрайвер отмечен восклицательным знаком.</span><span style="float:none;background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;"> </span><span style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">Я попытался обновить драйвер, но проблема с драйвером в диспетчере устройств не была решена. </span><span style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">Не могли бы вы рассказать мне, что делать?</span>
<div>
<div>
	<img alt="ed83b3b6985f.jpg" class="ipsImage" height="540" src="https://a.radikal.ru/a32/1809/a1/ed83b3b6985f.jpg" width="960"></div>
<div>
<div>
	<img alt="cf170e43848b.jpg" class="ipsImage" height="540" src="https://b.radikal.ru/b00/1809/1a/cf170e43848b.jpg" width="960"></div>
Your ccleaner is out of date. if I recall correctly windows old cleaning rule has been removed in newer versions for exactly this reason.
Ваш ccleaner устарел. если я правильно напомню, что правила старой старой очистки были удалены в более новых версиях именно по этой причине.
wasn't the default setting for windows.old set to NOT clean, so unless changed, CC shouldn't have wiped the driver.
but yes, as Nergal says, the whole option has now been removed.
get the latest Intel driver from here; https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10?product=80939
А какие вообще флажки для очистки можно повключать чтобы не повредить систему?
And what general flags for cleaning can be turned on so as not to damage the system?
if all CC options are on their default settings, that is the 'safe' cleaning method.
you can add INCLUDE's and use winapp2.ini for further deeper cleaning.
personally, do no run the reg cleaner process in CC, there just isn't any speed or space value in doing so, apart from it being completely unnecessary.
and if you click the Analyse button first (instead of Run Cleaner), you'll be able to go through what will be cleaned and check no sensitive areas will be effected until you can put your faith back into the program.
Is it safe for the operating system to clean with these flags enabled in the ССleaner settings?
Memory dumps
Fragments of files Chkdsk
Log Files Windows
Windows errors reports
Cache DNS
Windows Event Logs
Old prefetch data
List of recent programs
Way of Encircling
Безопасно ли для операционной системы выполнять очистку с включенными этими флагами?
Дампы памяти
Фрагменты файлов </span><span style="background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;min-height:0px;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">Chkdsk</span>
Файлы журналов Winows
Отчет об ошибках Windows
Кэш ДНС
Журналы событий Окна
Старые </span><span style="float:none;background-color:transparent;color:rgb(34,34,34);font-family:arial, sans-serif;font-size:16px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">prefetch </span><span style="font-size:16px;">данные
Список недавних программ
Путь окружения</span>
is it safe - yes.
is it what you want - only you can say.
you will lose some historical data, that may help troubleshoot events but if that's OK, then yes, delete them.
Got to say that I like that translation "Way of Encircling", it sounds a very zen. (or maybe Yoda).
Interestingly paste the russian, Путь окружения, into google translate the use the swap arrows to translate it back and forth.
It goes to- Способ окружения
Which goes to- Environment mode (Which is closer to the original Environment path).
Then settles down at- Режим окружающей среды and Environment path.
I just find it interesting how these online translators work, or sometimes don't.
