This morning i found something incredibly terrible!, i was going on www.systemrequirementslab.com and check if i could run Vanguard, then i see that my Ghz is only 2.99! , I usually has always had 3,77!
CPU:
You Have: 2 processors running - Genuine Intel? CPU T2300 @ 1.66GHz.
CPU Speed:
You Have: 1.66 GHz Performance Rated at > 2.99 GHz. <
This is sooo creppy... and im really scared i lost something, i already had this shiat on repairs for 2 months, and i cant stand another one... Please someone help!
(It has been showing that it has 3,77 for along while ever since i got it back though)
You could possibly set it back to normal in the BIOS if it really has been under-clocked when you sent it in for repairs, NOTE: there may have been a reason for this.
After visiting their site and using their tool, my fans started acting up. Also told me I couldn't run a game which I already run, although they linked me to a site to buy necessary equipment.
I re-installed XP, fans work properly again. Never hear them unless I am running the game they said I couldn't run. Or at start-up.
I will never ever even consider using their tool again.
