Hello
I just downloaded this software and I have run it. I saw that my CPU has a temperature of 12C. Is this normal?
Adding screenshot.
Kind regards
keikoki
Hello
Adding screenshot.
Kind regards
keikoki
It's not correct however judging by the graph it does appear Speccy is obtaining statistical data from the CPU sensor.
There are 2 possibilities for this error: a) the sensor is defected and sending the wrong values / motherboard needs a firmware update b) Speccy isn't reading the data correctly.
The only thing I could suggest is try another application for reading temperature (I believe the BIOS Setup should have a page for this data) and see if you have the correct temperature.
Richard S.
That would be great if Speccy shows together with the current temperarute, the normal temperature value like BIOS does.
