Hello
I am new to CCleaner. I used to clean TEMP folders manually. I tried cc and while it does much more it misses one of the temp folders, so I clean it manually (again).
Hello
1. Open CCleaner.
2. Go into: Options -> Advanced
3. See if this is ticked, which may be the reason your Temp folder isn't cleaned:
Only delete files in Windows Temp folders older than 24 hours
Screenshot:
I personally always leave it unticked, and it's never caused me any problems.
That was the problem. Thank you Captain
