is it a virus or normal ... task manager shows that taskeng.com opens every time CCleaner is opened ... did not do that previously
Do you have ccleaner setup to skip uac? Ccleaner uses a task to enable skipping.
did not set anything myself ... don't even know what uac is ... could program update have done it?
No, it couldn't do it on its own, though you may want to check the options screens just in case.
Edit: also do you have ccleaner setup to clean at start-up, not sure it matters but good to check.
found it ... duh ... checking options helped ... it was the skipping uac ... thanks
Hope this solves your issue
