Targeted Uninstallers/Removal Tools for Anti-Virus and other software
Although we can uninstall the existing anti-virus using Windows "Add/Remove Programs" (or Programs and Features) applet but its not a perfect solution as sometimes it doesn't remove the program completely which can interfere with the newly installed anti-virus program.
Link
Supplement Link (Provided by Abu Aufa)
More Uninstallers (From Hazel)
My immediate thought is that's a damned good idea, as we're regularly searching for the correct tools for various difficult to remove applications.
We'll see what other comments are forthcoming, but that's not a bad idea at all on the face of it.
Here is a NET Framework Cleanup Tool to remove corrupt NET Framework installations:
http://blogs.msdn.com/astebner/pages/8904493.aspx
I like the idea.
Good link ishan, as it leads to other links on that page such as the free rescue disc to boot your pc with and scan for nasties when it won't boot.
hey thanks for the link,great post.
Very nice indeed :)
Avast is a little more tricky since it leaves stuff in "C:\WINDOWS\system32\config"
Don't forget about all those registry entries that all of them will create that will be locked in various ControlSet areas of the registry that tools like Revo Uninstaller, Total Uninstall and ZSoft Uninstaller just can't deal with, they have to have the permissions manually changed to Administrator then manually deleted.
Nice find ishan_rulz, I've emailed that link to myself to make it easy to find, that'll save a lot of searching in the future.
Nice one, ishan_rulz. Saved the link in a notepad file named so that I have at least some chance of finding it when I need it. :P
Welcome!! :)
Andavari, does the avast uninstaller do the job completely?
I like the idea.
Here is a link to the biggest list I have ever seen of malware tools. It has a bunch of rescue disks on it and many other apps I had not even heard of. It's worth checking out. http://www.techsupportalert.com/content/pr...-list-world.htm
It's rather good at getting rid of everything except for the files in "C:\WINDOWS\system32\config" and the registry data in ControlSet areas (that's plural) of the registry. Other than that they have a stellar uninstaller.
Actually every antivirus, and firewall I've ever used places registry entries in the registry ControlSet entries, and not one of them removes them at uninstall time. That registry data doesn't hurt anything, however it's another reason why it's good to track the installation of them or anything for that matter so you know where stuff is, and can at least make sure the uninstall is complete which sometimes details a little manual cleaning.
And for those of you who need a general uninstaller... Revo Uninstaller is a great program to have.
AJ
Thank you, Andavari & CTskifreak. :)
It might be a ggod time to remind folk that if you are having problems uninstalling a product such as an anti-virus or firewall, boot into safe mode and run the uninstaller from there. Quite often this may mean you won't have to resort to using a specialist removal tool for it.
Also reboot twice after uninstall as this makes sure any of its drivers are uninstalled too.
Microsoft One Care Live install clean up tool (due to be discontinued on 30th June 2009.)
http://social.microsoft.com/Forums/en-US/o...2d-d261e3965943
Zone Alarm Security Suite (xp)
http://forum.zonelabs.org/zonelabs/board/m...essage.id=86638
After consulting with the other mods, it's been decided to pin this thread, for obvious reasons.
For now I'll pin it "as is", and give our young poster the credit he deserves for coming up with this, but I think because of it's valuable content, we'll have to clean this thread up shortly, and take out the unneccessary posts, and present it in a more concise way, and even maybe in a more appropriate part of the forum.
That means some of your posts, including mine, will be "cleaned". :lol: (Couldn't resist).
If anyone has any objections to that, please let us know.
Well done ishan. Great find.
Clean away, baby. :lol:
or this Supplement Link if above broken
A shed load of targeted Uninstallers from a good find by hazel.
Hazels original post:
http://forum.piriform.com/index.php?showtopic=22774&hl=
List of Uninstallers:
http://www.freewaregeeks.com/?&show=1&...ry=59&mode=
