CCleaner used to be quick and smooth. But with the last major version, now when I start CCleaner, it takes quite a while before the Analyze and Run Cleaner buttons are available. Everything works fine from then on, but it's a tad annoying that it takes so long to become active, especially since that didn't happen with the old versions. Any suggestions? Other than the ol' "uninstall reinstall" which I've actually done. Thanks!
You have a winapp2 file or other enhancing software for Ccleaner, yes?
Yes, indeed! CCEnhancer 3.9. Do you think that's related? I've had that for a year, and the slowdown has been happening for a lot less than that, so I didn't think they would be related.
BTW, I love your "interests"!
It is related and while I can not provide support until it is removed, I can say a search on this forum for a thread started by @Alan_B about Trim.bat might be informative.
