TabVault data cleaning
TabVault is an extension for Opera to keep links. Something like favorites. Since some moment CCleaner deletes data kept in it. I'd like to prevent this deletion, but I didn't find any option for doing it.
Add the relevant files to options -> exlcude
Firstly, I don't think that extensions data needs to be deleted without special flag.
Secondly, I don't know which file (if it's a separate file, maybe not) I need exclude.
Perhaps one of our Opera-using members can help you better than I.
Paging Dr. Nut.
Dr. Hazel Nut, you're needed in OR3
Now I can't reproduce this situation using CCleaner 3.25.1872 (x64) and Tab Vault 2.5.5.
