System Tray
CCleaner is a great program but I do have a feature request.
1) System Tray Tool
Currently CCleaner incluedes tools for Uninstall and Startup progammes and processes. It would be nice to have such a tool for System Tray processes as well.
Currently you can only clean all system tray related processes at once.<br>My suggestion shows a list of all system tray processes (similar to the tools Install and Startup) and then manually select the items that should be removed from the system tray. Which might need to reboot your system to take effect (or stop and restart explorer.exeagain).
2) Minimization of CCleaner to the system tray
When I preform a CCleaner cleanup I minimize the program to the taskbar, but I would like to see it minimized to the system tray instead. Is this prossible to do?
