I have Speccy set to minimize to the system tray where it displays my CPU temp. Every few days or so I notice it hasn't changed in a while and is displaying an unexpected temperature. I double click the icon to open the window and it shows a completely different temperature (that actually looks correct). Then I minimize it again and it works fine. Not sure what makes the tray icon freeze but it's pretty annoying. I'd like to be able to monitor my CPU temp without actually having the window open.
What is your operating system?
(when devs read bug reports they need as much info as possible )
known issue perhaps.
http://forum.piriform.com/index.php?showtopic=42580&p=257527
I'm using Windows 8.1
mta: Weird, I can only see a dozen topics in this forum unless I use the search function (which I didn't bother with before posting because there were only a dozen topics). I followed your link chain all the way back to September of 2013. I think it's sad that it has been reported several times over the last year and a half and it still hasn't been fixed. That makes it look like the developers don't really care.
System tray icon still freezing in 2019.. this will never get fixed...
