System Restore Points Being Erased
After using CCleaner, my system restore backup points are erased. They are not erased right away, but are erased after my pc is turned off overnight for about 12 hours. I'm using version 1.38.485 and Windows XP Pro.
If I don't use CCleaner, the restore points are never erased. I verified this over a 3 week period.
I like to keep my restore points. Is there any CCleaner setting that can prevent the restore points from erasing?
CCleaner works fine otherwise...
Syga,
Have aread of this thread, I am sure you will find an answer there
http://forum.piriform.com/index.php?showtopic=6021
