- Introduces integration with VirusTotal.com, an online antivirus analysis service. When enabled, Process Explorer sends the hashes of images and files shown in the process and DLL views to VirusTotal and if they have been previously scanned, reports how many antivirus engines identified them as possibly malicious. Hyperlinked results take you to VirusTotal.com report pages and you can even submit files for scanning.
Updated mine yesterday. Process Explorer is a must have, it is so configurable. I mean you can set it view system information, select columns to show the startup times and load order of things on your machine.
Right-click on anything in the list and select properties, will let you see all you need to know about that process.
This release fixes a bug that could cause a crash when the VirusTotal column is added to the process view, and another that could cause a crash when verifying digital signatures.
