Swf flash animation
Hi, I?m looking for a tool that can convert swf files to picture format files. The output formats would be a sequence of png, jpg or animated gif. Any suggestions?
PS: If software to do this doesn?t exist then I?ll accept an output format in mpeg. Thanks for your help.
Hi Adolph, and welcome to the forum.
I've never carried out the process you refer to, so I'm only guessing that this freeware application may do the trick:
SWF Picture Extractor 1.6:
EDIT: The download for this app is at the bottom of the home page Softpedia links you to. I've tried the download, and it is freeware.
I have used iWisoft SWF to Video Converter, it can convert swf to picture formats, the quality is good, you can try it.
Check this link http://bytescout.com/download_freeware.html ;)
hope useful :)
as i know, there are many swf to video converter can do that swf to image format, you can try this swf converter. it works well for me, maybe it can help you as well.
