Dear folks at Piriform,
I'd like to request support for "NTFS Folders" (aka mount points) for Recuva:
To be able to pick mount points at the dropdown left of 'Scan' where currently all drive letters are listed.
I use one of those USB devices with slots for many different flash cards. I end up with 6 drive letters which I find hard at times to associate with a specific slot.
The Screenshot above shows the configuration at Computer Management / Disk Management. I basically removed all drive letters and assigned specific folder with meaningful names.
Since I'm no application programmer it's hard for me to foresee how much work this would cause.
I think however this suggestion is technically possible since for example the application "Diskeeper" shows mount points correctly.
Thank you for your time and dedication to write freeware applications,
Cheers,
Marc
