If you do not already have a winapp2.ini file, please place that in a text file and save it as "winapp2.ini" in your CCleaner directory. If you do have a winapp2.ini file, add that to it.
I cannot help with your other requests. Perhaps another forum member could.
A bit offtopic but it might be helpfull to the poster aswell, could you link the Winapp2.ini link, search came up with to much stuff to find the right post xD
The "official" winapp2.ini is located here if you use windows vista/7 or 64 bit versions of windows, you may want to check out this winapp2.ini which provides for support for xp, vista, and 7 32/64bit
Thanks alot
Well I got multiple systems really but I was looking for the XP one (Still the most stable out of the 3 if you ask me... *sigh* dmn microsoft lol)
But again thanks I can add some stuff, still looking for the paths to clean in XBMC and some other apps (but that's for home use really )
Or you can input your Temp folder as an Include in CCleaner:
1. You'll first need to open in Windows the 'Folder Options' and then enable the view of 'Hidden Files and Folders' to add your temp path. Remember to undo this setting when done.
2. In CCleaner: 'Options > Include', then select the path you want to clean.
3. Then under 'Cleaner > Windows > Advanced', enable/tick 'Custom Files and Folders' so it will clean your Include path.
Recommend using Analyze first though before committing to Delete!
I have had a few gigabytes of trash in temp folder i don't know why Ccleaner won't cleaned it up
I must say that registry cleaning function in CCleaner sux! I've used it and I lost my settings in Orca Browser, Tlen.pl Communicator and few other applications and what's weird i've lost my savegame in game Blacksite Area 51
Before cleaning up the registry all was fine, unfortunately i didn't used registy backup - this should be made automatically
In version 3.11 it has been tamed down allot and is safer. However as with any registry cleaner you may or will need to input some exclusions. To learn how to exclude something in the registry cleaner see this post:
