I really like the program, and it actually works unlike some others (at least with my pc)
One thing I would like to see though is an option to display all the current temps of your computer in your taskbar, like have it show the current CPU temp and then if you hover over it it slides out and shows you all of the other temps, HDD's, Motherboards ect.
To be more precise, tray icons! It would be great, if you could select (in the options) which temps (HDDs, CPU, ...) or even other readings (like clocks) should be displayed in (probably multiple) tray icons.
Things like temps should be visible at one glance. And to this end Speccy should also have something like an autostart and background (minimize to tray) mode.
