Suggestion: Option to display temps in system tray
Hello. I didn't see this one on the forum. I currently use CoreTemp because I can monitor the CPU temps in the system tray at any given time. Since Speccy monitors the temps as well, could there be a way to display them in the tray like CoreTemp? (Especially the HDD temp.) Something in the Options menu with on/off choices for each temp application that Speccy montors.
Thanks for your time.
This was the first improvement I thought of too after using the program for the first time. If there was the option to enable temperature logging/monitoring and display it while the program is minimized to tray it would improve an already very useful and polished piece of software and would remove the need for me to use CoreTemp to do this job.
Also, is there the potential for adding any tweaking tools into Speccy? Or is it mainly just for viewing/monitoring system info?
Thanks.
