CCleaner can be used to delete one or more System Restore Points (SRP). I think the program can provide more details on how much memory these System Restore Points are occupying on a SSD or HD. I assume it's very difficult to determine what the size of each SRP is. So, then the program code could follow a different method that would nonetheless provide more information to the user.
1) Display all the SRPs that were found.
2) Read the size of the folder "System Volume Information" (= total amount of all disk space occupied by all SRPs) where all the SRPs are stored. And display the size of that folder in KB / MB / GB (whatever applies) under /above the list with these SRPs (what ever you like best) and display the % of total occupied disk space.
3) After the user has deleted one or more SRPs repeat step 2)
