[Suggestion for MrG] Install location for Piriform programs
Would it be possible in the future to make each Piriform program install in one single folder in the start menu rather than having each program install in it's own folder? What I mean is when I open up the start menu could whatever Piriform programs I installed be in subfolders in one easy to find folder called Piriform? Right now when each program is installed they're installed in their separate folders. I just thought it would be easier to find, not to mention making the start menu smaller, by doing this. I hope you take my suggestion into future consideration. Thanks.
Currently:
Start Menu > CCleaner
Start Menu > Defraggler
Start Menu > Recuva
Start Menu > Speccy
Consideration:
Start Menu > Piriform > CCleaner
... > Defraggler
... > Recuva
... > Speccy
I second the idea, it would help cleanup the look of the start menu.
That's not a bad idea, but it only takes 30 seconds to accomplish that on your own...
+1 Excellent idea.
Common sense design for any vendor's application menus.
Aside from ease of use, it reinforces the 'brand'; the idea that these are all part of the Piriform suite of applications ... not a disparate assortment of software.
I have thought about this as well. Would definitely simplify things.
AJ
This is a great suggestion. I would also like this!
Makes perfect sense to house them all under the Piriform name.
