Could you please add a Browser Helper Object remover under tools?
I use NirSoft startup run to detect & disable them. I would love to be able to drop it & only use ccleaner.
It is in only 1 place in the registry, & basically just another startup type of program, but there are many malicious programs that love to use BHO to control a PC or even hijack the desktop.
It is as simple as deleting or disabling the BHO & there are no definitions to update. There is only one place in the registry they appear. Period. Would love a tool to disable or delete BHO please!
Also, maybe a prefetch disable or control tool.
The new system restore control is NICE!!!! I LOVE IT!
Thank you guys!
In summary, all I want now is:
- BHO tool to disable or delete BHO
- Prefetch disable or control tool
