In the last versions, if I select a folder in the Include list, only the files are removed.
The last version to work well was 2.28.
Thank you very much for your great program!
There's an option with three choices for each include, just double click or highlight and choose edit.
Make your selection from the following then click OK.
Include files only
Include files and subfolders
Include files, subfolders and the folder itself.
I am having the same problem with 'Temporary Internet Files' files & folders not being deleted even though they are checked for deletion. I updated to see if that would help, but it has not. They do delete manually, but not with the program.
Love Piriform products, especially CCleaner. However I've discovered that it does not clean out the Temp folder on my Vista laptop as it does in XP environments. Is there some other option I need to set?
Hi Moosie, welcome to the forums.
Did you enable cleaning of folders younger than 24 hours?
I had a similar discussion with ""Mike Kennedy"" in june.
http://forum.piriform.com/index.php?showtopic=28475
When I read the posts in this thread then it seems that bug hasn't been fixed in the latest version(s). I don't experience any problems with this ""Include"" option in CC v2.35. So, the search algorithm seems to be OK. Therefore I still think that it's an memory issue. Perhaps this the result of a thing called ""memory leakage"" ?
