As shown in the clip above,,, my laptop makes this strange squeaking noises as soon as I plug in the power cord, and screen blacks out for about a split second.. I've found it only does this when it's cold from not running for a while - like when I turn it off at night and start up in the morning.
It has only recently started doing this. I got it 2 years ago, and I've gotten some pretty heavy use out of it.. think it be time for an new machine?
Maybe its time for a dust bunny exorcism as the fan act like a little vacuum cleaner sucking up whatever loose dust is near.
Look up "cleaning laptops" with Google.
Maybe it will last a bit longer and if you don't want to do that then I gratefully accept cast off computers.
