Recently when I open my CC strange thing happens: the right window stays transparent, so I can?t follow the cleaning process, which is obviously going on. Or worse, in the right window are showed parts of simultaneously opened windows. I?m using XP SP3, on Pentium 4 with 2,6 GHz, Intel 82865G graphics, Mozilla browser. Newly I registered another behavior variety, the right window isn?t transparent, but blank. Of course in this situation I?m not likely to proceed with cleaning process, not seeing the progress and the results of it. Any suggestions? Thanks in advance.
Hi able,
I haven't seen any other posts similar to your problem.
My system specs are the same as yours.
First thing I would try is a Restart.
davey
abel, welcome.
Have you modified the display settings in Display Properties then Advanced then Advanced Appearance?
