Still Does Not Clean Flashget 1.73
Just tried the latest build, also installed latest winapp2, still does not clean Flashget 1.73(The best & Most Favoured Build). Will it ever clean this app?
You Can But Try!
Flashget is listed in winapp2.ini. You could update the entry, it's not difficult to do if you study the winapp2.ini file which will basically show you how to add stuff. Just make sure you test it on your system first, then re-submit the entry to TwistedMetal.
Tip:
You should only add to the already included winapp2.ini entry, this is so that people still using old versions won't all of a sudden not be able to clean those older versions.
Tip:
1.73 is an older version, the latest versions are 'Bloatware'
Well then I'd say if you want CCleaner to clean it you'll need to craft your own winapp2.ini entry just for that version, or add to the already included winapp2.ini entry.
