The problem I'm having is CCleaner get to 28% and sticks, the file it sticks on is an old rar file, the only way I can get it to run through is by unticking empty recycle bin.
I download alot of rar files so I am emptying the bin myself because CCleaner sticks.
How big are the files you're having a problem with?
I download quite a few RAR files, and normally shift/delete them when I'm done with them, however I tried binning a few via the recycle bin with CCleaner and they went OK.
These were files of a couple of hundred mb, so not that big compared to some.
I have the same problem here.... CCleaner gets stuck on a already deleted rar-file (so recycle bin looks empty). But it only gets stuck with secure file deletion, so not with normal file deletion. Deletion goes to 29% and gets stuck.
No worries. It doesn't matter who fixes it as long as it's fixed. I was just reinforcing hazels suggestion and apologies if it sounded like sour grapes.
Thunder rumbles, lightning cracks in the background.
I'm not joking.
I will try it out in the morning.
Thanks both of you *bows*
Carcer
Dennis D, you have no need to apologise, you gave me a perfectly reasonable reply, the oops was my fault, posted and hit back one page, then forward one page, then back one page, If you get my gist?
We all chip in to help each other on here.
Exactly Dennis, as long as it gets fixed in the end that's all we care about
Let us know how it goes Carcer, if no joy we'll try plan 25.
Tried out the 2nd option on the link you provided, rebooted, I now have a shortcut recycle bin, same issue not a rar file this time its an ISO CCleaner is stuck on.
(Obviously you didn't look under my avatar to see where I live... not too far from you, so I believe you as we had a torrential rainstorm around the same time!)
A "corrupted Recycle Bin" in the past what I've did is just right click on the hard disk where it's corrupt to create a blank New Text Document, delete it, then use Windows own built in Recycle Bin cleaner. Of course this doesn't mean you'll be able to secure delete the contents but it should sort out the Recycle Bin not behaving.
I actually had thunder and Lightning going on in the background, no joke, serious!
I'm in Sheffield, Check out the weather report Hazel!
I'm just up the road from you in Co.Durham, and although no fireworks, we've had a monsoon coming down tonight. I was half expecting to see the Ark floating past.
