startup problem with ccleaner and Vista Business
First let me thank you for CCleaner. It's much appreciated.
I have a little problem at start up with CCleaner.
I usually run CCleaner every time I start up Vista
Windows Vista Business
Service pack 2
All updates in effect
Latest CCleaner
What is happening:
Startup Vista
Eset smart Security kicks in and does its thing.
I then dbl click on CCleaner and it just sits there doing nothing
I then go into FireFox (as an example) and start to do something.
Then CCleaner butts in to do its thing.
I've been struggling with this problem for a very long time.
Today I totally uninstalled CCleaner(using Control Panel) and had trouble deleting all of CCleaner out of the Puter.
Had to go into Safe Mode to completely delete everything.
Reinstalled CCleaner with CCleaner to run at startup.
Went into CCleaner/Options/settings - put check in box - run CC when Puter starts
Went into "msconfig" and system configuration/startup and CCleaner is there checked.
None of this made any difference.
I feel it is something in the Vista and my mix of programs causing the problem
No error messages of any kind.
Regards,
Surely there must be someone who can help me with my problem.
Not seen anyone that I recall using eset with a ccleaner problem.
Are you able to put an exception in the eset rules for ccleaner?
If you have ccleaner check for updates, try unticking it.
Do you have the slim version of ccleaner or the full version with yahoo toolbar?
Thank you for replying,
You pointed me in the right direction.
It seems that ESET is the culprit.
So I will go to them for help
Is everything ok now? Because mine didn't work. I hope you could tell me what you did.
Regards,
Louise
Regards,
Louise
I'll tell you what I did louise I removed your spam link and banned you :)
