Startup Cleaning
My CCleaner makes automatic cleaning on startup,but after cleaning is done CCleaner automatically closes unless i maximize it while it cleans,but in "Options > Advanced > Close program after cleaning" is disabled..
I'm using Windows 7 Ultimate SP1 32bit
I think this may be the inteded behavior.
"Close program after cleaning" is only used when you manually start and run CCleaner yourself, it has no barrings over the automated settings. That setting isn't used when you have CCleaner automatically clean all on its own, as it would sort of defeat the purpose of making CCleaner automatted.
OneDarkLord, yes...
CCleaner automatically closes after cleaning if you set it for automatic cleaning. If you had to have manual interactions, it wouldn't be automatic.
